Marine 31 coating questions
Jeremy5431
Hey Mike,
I saw another user use the Marine 31 coating on their boat and decided to give it a try as well.. It will be my first time applying a coating, so I have a few questions
1. Can I use all purpose Mf towels after polishing to remove excess polish?
1. Can you apply the coating over the top of vinyl graphics?
2. Can. I use d101 to remove polishing residue? What strength?
3. One of my boats is white and my jetski is blue/black. How can you see how much product you are using and how do you see high spots?
4. Can I use all purpose MF towels to remove excess coating?
5.. After the coating cures, can I apply a liquid was to increase the gloss?
I typically use a waterspot remover after each use will that remove the coating?
Thanks for your help Mike. I really appreciate how helpful thee tire staff at auto geek has been..
Hey Mike,
I can try and answer some questions.
1. I used all purpose MF towels to remove the coating and buff.
2. I applied the coating over the graphics and striping on my Chaparral with no issues.
3. I used an APC at 4:1 to remove any residue and prep for the coating. Just make sure you wipe down again to remove any residue from the APC before the coating.
4. Yes
5. I decided not to top my coating. It looked great and had a ton of gloss.
Hope it helps.
