McCulloch Steamer - Partial Review
  • Thread starter Thread starter Kappy
  • Start date Start date
K
Kappy
Guest
Due to circumstances beyond my control, I can only give you a limited review at this time.
My dog hates the steamer.
He's fine with a vacuum cleaner, and in fact, often does his impression of a speed bump so you have to vacuum around him. There's something about the hissing noise of the steam jet that he doesn't like and he kept barking at the steamer. Hot steam and dogs don't mix, so I was limited to what I could try because I was afraid that he was going to make a lunge for the steamer hose.
From what I can tell, the steamer itself seems well-made. It comes with loads of attachments, and they even provided a screw driver so you can tighten one screw that attaches the handle to the steamer.
According to the manual - which I read - you have the option of using 16, 32 or 48 ounces of water, that gives you about 15 minutes of steam for each 16 oz. The manual also indicated that it takes 2 - 8 minutes to heat the water, depending on the amount. I used 16 oz and I think it took about 4 minutes to bring the water up to temperature. There's a red indicator light that goes off when the steamer is ready to use. It might be a problem for someone who is going to need more than 45 minutes of steam because the manual suggests letting the steamer cool for 20 minutes before refilling, but that's not a concern for me.
I didn't test any attachments and was just curious about the power of the steam jet itself. I tried steaming some white grout before my dog went into attack mode, and a short blast of steam, along with a brush, removed the dirt and whitened the grout. Even though there was very little water I dried the grout, because it's the dirty water that settles back into the grout and evaporates, that makes the grout dirty in the first place. If every time I washed the tile floor I could thoroughly rinse and dry all the grout, the grout would stay white. (By the way, I have tried a Garry Dean Method Sort Of No Rinse Floor Wash, but that's a story for another time.) While I can get a similar result spraying the grout with an orange oil solution, letting it stand a few minutes, scrubbing it, rinsing it and drying it, this was much faster. Next time I'd like to try one of the brush attachments on the steam jet and see how it works.
The steamer also instantly brightened some white trim around the dishwasher, something that I haven't been able to do even after trying a variety of products.
I realize that this is a car forum and I'm sorry I don't have any car related tests to report at this time. It's so hot in my garage today, that all water vaporizes, so I have to wait until it gets a little cooler before I can play with the steamer outside. Even so, there's nothing on my car that's dirty enough for testing, but I might try it on the engine.
One thing to note is that the steamer does produce moisture. By that I mean that you just don't blast the steam and get instant evaporation. I stand behind a comment I made after watching HateSwirls video showing how he used the steamer to clean the dash around the radio, and some speakers. I wouldn't use the steamer near any electronics because I think it produces too much moisture, which could cause problems. On most surfaces I think it would be safe and effective, but I'd rather err on the side of caution and not cause any damage.
One more thing. When I opened the box I was concerned at first because there's a card that mentions only a 30 warranty from Harbor Freight. I checked the manual and it says that the steamer has a 1 year limited manufacturer's warranty so I'm assuming the 30 days is just for purposes of returning it to the store, and after that the manufacturer takes care of any problems.
Sorry it's not the most thorough review, but it's all I can provide for now. My excuse is an updated version of my dog ate my homework. :)
I bought this unit
HomeRight C800880 SteamMachine Steamer for Steam Cleaning and Wallpaper Removal. Its basically the same exact thing as the Mcculloch but just a different name and cost only $65. It works really well also.
My car doesn't get that dirty so I haven't used the steamer as much as I initially thought I would.
It did come in handy cleaning some hard to reach areas in the wheel wells after an ice storm two weeks ago. Between the sand they put down and the dirt from the melting ice on the road, it was like a layer of cement had dried behind the tires. I tried some soap with a brush, and then some OPC, but still couldn't remove all the dirt because I couldn't reach it. I used the steamer to shoot some steam in there which did the trick.
I also melted a small brush attachment. You have to be careful to let the steam cool slightly before brushing, or the bristles get soft and bend.
Thanks!!
Would you please speak on just the two specifics of wheel cleaning (baked on road grime, brake dust, iron deposits and so forth, without using $100 a container purple-activated wheel cleaner that now flood the market), and secondly, removing stains from headliners/carpeting/upholstery?
How long do you find one full tank lasts, and how long from filling up to being totally heated and ready to use would you say it takes?
Thanks!!
Sorry, but at this point I don't have any experience with the type of cleaning you're asking about.
I've never filled the tank past a third of the way, which is 16 oz., and it seems to take about 4 - 5 minutes. According to my original post, it's supposed to take 2 - 8 minutes to heat the water, depending on the quantity. I'm not sure why it's taking 5 minutes with just 16 oz., or if filled to capacity if it takes 3 times as long to heat or not.
From above:
Have mine for a couple of years and not once has it ever gave me trouble.
I've put it in the back of my truck while on detail jobs and still no problems.
Good pressure.
Decent run time.
Sturdy.
Nice attachments.
Good price.
Perfect if you need it a few times per year.
I just ordered this model and it should be here Friday. Can't wait to use it!
I recently purchased this same steamer to clean interiors. I havent had a chance to try it out.
How does this work on cleaning carpet?
how do i dry the carpet and pick up the left behind dirt?
Sent from my SPH-L710 using AG Online
I wrap a plush MF towel around the large head and make a few passes to clean.
It doesn't wet the carpet too much so not much to pick up.
However once done I use a large drying towel and blot, blot, blot. :dblthumb2:
From above:
Great info, thanks. I didn't go back and review the August posts, but you're right you listed the warm-up times, which aren't too bad. I was wondering if anything had changed with continued usage, hopefully the product is holding up well and still like new for you.
If you're melting attachments, and only waiting a few minutes for 16oz of water, I'd say it's a great machine, although the only two remaining variables would be actual steam "pressure" and the longevity of the machine. But... for $100, and in some cases less I would assume if you shop around or wait for deals, it's a LOT less of a concern than the $1,000 "professional" machines.
Good pressure.
Decent run time.
Sturdy.
Nice attachments.
Good price.
The pressure is what I was wondering about, thanks a lot. This may definitely be worth trying out, especially with Amazon's pretty lenient and fair 30-day return policy. I'll also go check out their manf warranty, if it's a year parts and labor, and not just a limited manf-defect warranty, it will be worth it for SURE
Let us know and good luck :)
Thanks!!
I have used it to clean wheels, but it's more time consuming than using a ferrous fighting wheel cleaner and water. However, if there are spots on the wheels that you can't seem to get clean (built up dust/grime) then this machine will knock it completely down.
I also use mine for stains inside the car and the house. Couple it with Folex, a specific stain remover or an APC and it works great.
Thanks a lot :)
Between Home Depot and Amazon, there are way over 1,000 reviews total. Many people love this thing, but a lot of people are angry about the nylon bristles literally melting, and some people said it was so useless they got better results using oxyclean and a toothbrush on grout... but there were a lot of 4-5 star reviews too. Thanks for the help!
i got mine about 3-4 weeks ago, but haven't had time to use it :cry:....i am excited about it though.
Thanks a lot :)
Cleaning grout is how I melted the small brush attachment. After that I switched to a small hand brush that I had been using with other grout cleaning attempts, and had no problem with the bristles in this brush melting.
Speaking of which, I tried some OPC as a grout cleaner and it's probably the best product I've ever used to clean grout. It requires a little more rinsing than steam, and still needs to be agitated with a brush, but the OPC really brightened the white grout. I started with a 6:1 solution, and it seemed to work just as well when I increased it to 10:1.
I ordered the HomeRight C800880 as well. Hope shipping from the US to Canada won't take too long at this time of year. This should be a good upgrade from my hand held unit. 40 minutes of steam is gonna be overkill for the way I use those.
Thanks a lot
Looks like they have a whole new website and more products that are even better.
Anyways, here is the difference between the original brush and a brand new one that came as a replacement. (well they feel like the same stiffness)
...and here is how I mostly use mine
For the price, it has worked perfectly fine for me and I couldn't live without it now.
As far as using it in the bathroom; I like to couple it with brushes/towels with a bleach item, but it does work regardless. Of course it has its limitations.
