Andre
Super Moderator
- Sep 3, 2013
- 167
As soon as the new McKee's 37 High Gloss Detail Spray came out, I knew I had to take it for a spin! This Ford Mustang was perfect for the job. It sat outside during Florida's pollen season and was caked with it pretty good. The pollen got really bad down here for a couple weeks. I desperately wanted to see just how glossy the end results would be and not to mention how well the product safely removed the stubborn pollen off the car. Time to spray, wipe, and buff
rops:
The mist is extremely concentrated so only a few pumps covered the cleaning area easily
My favorite towels to use with quick detail sprays - Gold Plush Jr. Towels. Just look at how the dirt embeds right into the plush surface
Just LOOK at that GLOSS!!! Im the MANI'm SOLD
This is a cool read that was posted by a Forum Member (TOGWT ) back in 2008:
Pollen[: Micro gametophytes - pollen grains]
"The sky is falling, the sky is falling" Chicken Little
The yellow fines to coarse powders you see in the air is made up of small sperm cells from blooming plants and are one of the most common allergy triggers. The pollen from trees are the main concern, vehicles get hit with pollen laced trees that include: oak, western red cedar, elm, birch, ash, hickory, polar, sycamore, maple, cypress and walnut (which also leaves an oily residue). Pollen grains of pines, firs, and spruces are winged.
Pollen must be strong to protect the male gametes on their journey. The outer wall of the pollen grain, called the exine, is composed of a very unusual substance called sporopollenin which is very tough. The inner layer is made of cellulose and is similar in construction to an ordinary plant cell wall; pollen will literally ‘wear’ away wax or polymer sealants.
Pollen isn't removed by air friction as you drive because it adheres to a surface with microscopic barbs that can attach to even a very slightly uneven surface, and adheres to a natural wax better than a synthetic polymer. As well as being allergic pollen is also very abrasive (due to its exine or barbs) and slightly acidic dust, especially when mixed with moisture and should therefore be removed from paint surfaces as soon as is practicable.
In conclusion:
Do not try to "dust" off the pollen because it will more than likely cause marring due to the pollen exine... Use a dedicated quick detailer, waterless wash, rinseless wash, 2 bucket wash system, etc.. that contain lubricants and surfactants to prevent marring on the painted surface (epecially with pollen). The McKee's 37 High Gloss Detail Spray had plenty of lubrication to prevent marring but also finished out extremely glossy. Pictures don't even due it justice. I have many favorite detail sprays, after using the McKee's 37 High Gloss Detail Spray, it's definitely up there on the list. At the great price point, I highly recommend buying a bottle and trying it out for yourself. You will not be disappointed. Thanks for reading
In conclusion:
