Joe@NextLevelDetail
- Jun 4, 2015
- 1,929
I recently got called from a recent customer of mine, I had the pleasure of working on his Porsche, And he was so impressed with my work that he wanted to get his wifes Passat done, The challenging thing about this im currently doing mobile calls in Florida, And I have to detail at his apartment complex with no hose access. So I am always looking for ways to make my Mobile details more efficient even in the more challenging ones.
So Let's take a look at the wheels.
Application:For application I misted the entire wheel. As I sprayed I moved the bottle to ensure coverage and use less product.
Smell: this product does not smell bad at all, Infact you it is quite mild, compared to similar products.
After a few mins, The wheels started to bleed red.
McKee’s 37 Xtreme Iron Remover is pH-balanced and 100% acid-free: So why did i decide to go with this product? Due to it being pH balanced and acid free, I do not have to worry about rinsing the Iron Remover Residue with a hose, I can use something simple like my pump sprayer or even some N-914 in a spray bottle to wipe off.
Time to Rinse Off: I Used my pump sprayer that i use to pre-soak with rinseless washes. (I had some N914 @ around 1.5:128)
With my pump sprayer, It blasted away all the brake dust, grime, and residue! NOTE: I did not agitate dirt or use any wheel cleaning tools, Simply sprayed product let it dwell and rinsed off.
Results
Before
After
Conslusion
This product saved me a ton of time, It literally did all the work for me, I did not have to use any tools to agitate. It took 3 simple steps, Spray, Rinse, Dry. You do not need a pump sprayer to rinse the residue off, You can use something as simple as a spray bottle with N914 rinse and dry with a microfiber towel. The product also goes a long way, The key is to not spray in one area, When you spray move the sprayer to coat the entire rim this will ensure even coverage and using less product, I only used 15-20% of the bottle. Iron Remover also comes at a very attractive price point even for professionals. One of the most surprising characteristics of this product is that it does not smell as bad as the other Iron removers on the market, It is actually a pleasant suprise. I am very sensitive to headaches with certain chemical smells, and Iron Remover really surprised me!
I highly recommend this product, Any vehicle that produces a ton of brake dust has no chance.
Results
Before
After
Conslusion
