Mckee's Hi-Intensity APC
nine
Is this safe for cleaning wheels?
I just read in another post to stay away from it on clear coated wheel. Poster stated that I might not notice anything bad on first go around but continued use will lead to negative effects.
I've used this a couple times now....is it ok to continue?
Ive been using Mckees Hi-Intensity APC diluted 4:1 on my clear coated wheels and have not noticed any negative affects.I also put soap it my tire brush bucket so that might help tone down the aggressivness, but I'm sure others that have used it a lot longer than I have will start to chime in. Hope this helps.
Sent from my SAMSUNG-SM-G935A using Autogeekonline mobile app
Hi-Intensity APC is a great wheel cleaner when diluted 1 part concentrate to 4 parts water. However, you'll find that our Foaming Wheel Cleaner Gel works better because it was designed specifically for wheels, plus you'll use less product because the primary ingredient targets ferrous (iron containing) brake-dust particles. Not to mention it creates a thick, foamy lather that protects the wheel against scratches as you clean.
McKee's 37 Foaming Wheel Cleaner Gel 128 oz.
