Meg DA using LC 5' plate + MF DA cutting and finishing pad 5"
terentius
Hi Folks
Is there a different in Meg MF DA 5" back plate and LC 5" backing plate.
sound a little silly but use want to make sure the LC 5" goes will with the Meg MF pads and work efficently with the MF DA system compound and finish wax.
Hi Folks
Meg 5" DA back plate has a special small loop while LC has standard. You could possibly create extra unwanted heat using wrong back plate.
I agree with Mark....stick with what the manufacturer suggests for the backing plate. Its designed specifially for the system. Search the forum on excessive heat and pads and see what you find.
2 totally different BPs......using the megs mf system its recomended that you use thier bp.
If I am not using it for MF DA system
But using LC pads - can I use a LC plate on a Meg DA?
