rjgervacio
- Apr 12, 2011
- 88
What's the most effective product out of the 3 for paint correction and removing scratches along with the use of a GG 6" DA?
All three will work but it depends on how severe the surface defects are.
In terms of aggressiveness
I would consider both Meguiar's M104 and Pinnacle's XMT #4 heavy compounds. Meguiar's D151 I would consider at the upper end of a medium polish range..
- Meguiar's M105
- Pinnacle's XMT #4
- Meguiar's D151
Always start with a less abrasive polish, and if necessary resort to something more aggressive.
Can you recommend 3 polishing products (heavy, medium, light) that is not too expensive but have excellent results? So far, Im only familiar with the heavy ones, as mentioned above.
I'd be glad too!
Heavy Duty Compounds
Menzerna Power Gloss
Meguiar's M105
Medium Polish
Menzerna PO203S
Meguiar's M205
Light Polish
Menzerna PO106FA
Menzerna PO85RD
A very nice bundle of products that work very well covering all your reqirements.
Menzerna Power Gloss, Power Finish & Super Finish Bundle, Menzerna Polishes Combo, Nano Polish, Power Finish Polish, Power Gloss Compound
Pinnacle's XMT line is about the most economical line and is widely available. Starting with their #4 the most aggressive then line progressively becomes finer as the numbers decrease.
Pinnacle XMT #4
Pinnacle XMT #3
Pinnacle XMT #2
Pinnacle XMT #1
XMT Series by Pinnacle; Xtreme Machine Technology polishes & glazes for dual action orbital & rotary polishers.
Hey Bobby,
Where would you rank Wolfgang TSR and FG. I realize TSR is medium and FG light, and FG is similar to 106FA, so how do you rank against each in those lists? And what would be your choice in case I want something a BIT more aggressive than TSR? Or would you just switch to like a yellow pad and TSR?
Informative thread.
I have another question when you finish off with M105 > M205 what do you guys recommend after the 205?
I'd second that. You will probably find a few thousand others on this site that like that combo.Meguiar's M205 is a great polish and finishes up nicely on its own. If I want to bump it up a step I'll use Menzerna PO85RD..
