Megs DA Correction System compared to 105/205?
klix58
How much of a difference in the two? I have a small amount of 105/205 left and wondered if the DA System was better?
Hi Klix58. I think that the M105/205 is more aggressive than the DA System. In fact the 2 systems are completely different. The DA System works wonders with the MF pads while the M105/205 works wonders with foam pads. I cannot say honestly if you mix the both of them if you will get pristine results. Mike am I right?
Usually it's micro pad on both systems.or,depends what your working on.for me being mobile 105 just deosnt work.although I like the da correction system.The down side is the coloring additive,will stain single stage faded planes or rv.other than that it's a great solo compound even when working outside,there is no gumming up like 105.205 on a micro pad can usually clean and gloss up paint on a vast majority of paint systems.I would say in my opinion just get A bottle of da 300 compound and keep the 105 and 205,cause you never know when your gonna need it.
