SRTSean
- Jun 8, 2011
- 438
Unfortunately I've become one of the many frustrated G110v2 owners out there, and I've decided to put together this short review for others to be aware of when considering this DA polisher.
The long story short is that I have now cycled through 4 of these polishers within a little over 1 year's time, and every unit has failed. I'm a hobbyist with occasional paid clients, and do not abuse my machines or put a ton of hours on them that would justify a unit failing in anything less than 5 years.
The first three suffered from the typical power cord failure. To that point I was satisfied with the performance of the machine and was willing to overlook the power cord issue because I received a new replacement each time it went out, and because machine number four that I received was supposed to have the power cord issue finally resolved.
Machine number four became a whole 'nother can of worms as the Chinese "quality" again reared its ugly head. Since receiving this machine in April (it is an updated one with the power cord fix) I have seen it:
Fast forward to this past weekend and I'm working on my brother's 1995 Pontiac Formula Firehawk in advance of a local Pontiac car show. I get 3/4 of the way around the car doing a simple AIO detail and I get a couple seconds of audible short circuiting, followed by a puff of smoke and complete motor failure.
I have never purchased a single other product that had so many issues pop up simply from trying to use the machine as intended. I would strongly advise anybody considering one of these machines to think again. My 10-year old original PC7424 is still going strong, even after being subject to my years as a novice and probably being dropped a half-dozen times on the ground.
Pros:
Cons:
Final verdict:
Do not buy this machine. It even has me considering leaving all Meguiars products behind given the many other options available here at Autogeek.
- Lose all three screws holding the cover plate over the main bearing. When I tried to reuse them they weren't even the proper size and wouldn't tighten at all. I had to go out and buy new, larger screws to ensure this didn't occur again.
- Lose all three screws which hold the counterweight together. This was actually a bit terrifying as it happened while detailing a friends car. Thankfully none of the screws caused any damage as they flew off the counterweight. Again I went out and got new screws and used locktite to ensure they didn't back out again.
Pros:
- Adequate power (when it's not breaking down) for serious paint correction
- Slow-start feature is nice and smooth
Cons:
- Horrible quality
- It's not a matter of if, but when this unit will break and leave you high and dry
- 1-year warranty is inadequate if you buy this polisher
Final verdict:
