Megs last touch
frankprozzoly
I've used a lot of meguiars stuff. I would think last touch can be used for anything including the interior. It even smells better than megs quick interior detailer. This stuff does it all. Everything else seems unnecessary. Clay lube, quick detailer, rinseless wash, interior detailer. Not quite as good as express wash but if done indoors I think works just as good.
Me thinks its just a QD and clay lube. I'm sure it works fine on interiors, but using a concentrated product like UWW+ is cheaper and just as effective.
Ultima Waterless Wash Plus is a QD/waterless & rinseless wash/clay lube that comes as a concentrate with a very high dilution.
It's like the best $20 you can spend on a detailing product.
Is megs final touch the same as final Inspection ?
Sent from my SAMSUNG-SGH-I337 using AG Online
I've used FI and it is pretty good and reasonably priced. Having said that it is no better than any of a dozen other QDs. As another poster said, the main difference between FI and LT is that FI is formulated a little differently and is approved for Body Shop use.
I've used final inspection also. The reason I mentioned last touch is it says it's good for vinyl, plastic, rubber, quick detailer, clay lube. Doesn't say anything about rinseless wash but I don't see why you couldn't use it. Again it smells way better than megs interior detailer so I'm gonna use it inside too. For how good all of meguiars products smell im really disappointed in they're interior detailer
The best thing about FI is that it's static resistant which is awesome and it smells decent. Personally I love FI it's the clay lube I've used and it very slick and glossy, the only downside is it will streak if used on a warm vehicle.
Right you are about streaking but I think my problem was the humidity when I used it because I never noticed this problem before. Because of this thread, just a little while ago I sprayed the rear and trunk area of a Sonata with FI - I could not get it off! It streaked and would not buff off. I then used Griot's Speed Shine, another pretty good QD on the hood - it also streaked. Finally, I used Lucas Slick Mist on a side panel and door and it streaked as well. No doubt in my mind it was all due to the very high humidity this morning. From now on, no QD until later in the day when it is dry.
IMHO Meg's Last Touch is just an OK QD. It's not great and it's not bad. If your having streaking issues (Griots does streak), try Prima Slick. It may be the top QD made IMHO.
Aren't all products with water in them "static resistant"?
I belive so... Final inspection is also very versatile product in my opinion but I would compare it to optimum or ultima... but it's still a very decent product.
megs LT isn't a bad QD and since you can dilute it 1:1, it gives you a little more for your money. there are other QD's that i like better though...
FI also leaves nothing behind which is why I use it when applying sealant or final inspection before applying a sealant.
I can't see how FI can be "slick and glossy" but leave nothing behind?
Like I said, I've never used it...
