Megs Microfiber pads on a 7424
HardLineDetail
How much of a difference on power and correction will my PC be with Megs Microfiber disks? Can i use the disks with my currect products which are Menzernas SIP and super finish or is the megs products that come with the pads better? If so, how much better?
I was thinking of ditching out my pc for a flex to use for correcting and my cyclo for polishing and other things. (The Cyclo is amazing!)
But if i can squish some more power with the microfiber disks, i will stick with it for a while more.
This is the old PC not the xp. Will i get more power using a microfiber with the pc or more power just upgrading to the XP and using my lakecountry pads?
Thanks guys! :buffing:
MF pads have more cut than foam pads and most of us that use MF pads finish with foam pads. Yes D300 is a very good product cut very well that said you can use any compound you want with the MF pads. I use D300,FG400,105 and a few others with great results.
