Either will work.
D103 All Purpose Cleaner Plus
- Designed to be low foaming for use in carpet and upholstery extraction machines.
- Diluted at the same levels it's stronger than APC.
- Lower cost per ounce compared to APC.
D101 All Purpose Cleaner
That was taken from Mike Stoops over at MOL.
- More foaming which helps visually when cleaning carpets by hand and brush. It's important to note that in the detailing industry this is an important factor so a person can tell where they're working on a segment of carpet or upholstery.
- Fabric softeners and brighteners.
- Not as strong as APC+
- Higher cost per ounce compared to APC+
to me, there is no reason to even buy APC. Yes it foams more which helps with visibility. but I use APC+ by hand and I have never had any problem seeing what I am doing.
