Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
Meguiar's 6" Unigrit Sanding and Finishing Discs
Meguiar's new Unigrit Sanding Discs are specifically designed for damp-sanding and can be used with a 5/16" orbit sander. These Unigrit discs offer uniform particle size and placement over the face of the disc and are available in both 3" and 6" sizes.
Meguiar's 6" Unigrit Sanding and Foam Finishing Discs
Meguiars Unigrit™ 1500 6 Inch Sanding Discs - #S61500
Product Attributes
Meguiars Unigrit™ 1500 6 inch Finishing Discs - #S6F1500
Product Attributes
Product Attributes
Meguiar's 6" Sanding Backing Plate - #S6BP
Back side
Working face side
Product Attributes
Meguiar's 6" Foam Interface Pad - #S6FI
Back side
Working face side
Approximately 1/2" thick
Product Attributes
Intended Markets
Sanding Discs vs Finishing Discs
Sanding Discs --> Body shops
S61500 -> S6F3000 --> Machine Compounding
The S61500 6 inch Unigrit 1500 Sanding Discs are primarily for leveling surface texture like Orange Peel or for removing heavy surface defects like dirt in paint on fresh paint. Removes material quickly but with good control leaving behind a sanding mark pattern that is quickly and easily refined to a higher level using the S6F3000 Finishing Disc. #3000 Finishing marks are then removed using a rotary buffer.
Finishing Discs --> Detail Industry
S6F1500 --> S6F3000 --> Machine Compounding
The S6F1500 and S6F3000 6 inch Unigrit Finishing Discs are more targeted at for use by Professional Detailers to remove moderate to fine defects. These foam backed discs removes material quickly but with excellent control over the depth of the sanding mark left behind. The S6F1500 sanding marks are easily refined to a higher level or removed with a rotary buffer. The S6F3000 are easily removed with a rotary buffer and a cutting compound.
Air-Powered DA Sanders
These discs can be used with Air-powered DA Sanders like the 3M Orbital Sander.
3M Orbital Sander or D.A. Sander
Meguiar's G110v2
The also fit the Meguair's G110v2 but note there are no electric sanders approved for working around water.
The backing plate attaches to the Free Floating Spindle Assembly
If you choose to use the interface pad, the "M" logo attaches to the face of the backing plate. The "M" side of the Interface pad has the "loop" material while the face of the backing plate has the "hook" material.
The loop backing on the back of the sanding disc attaches to the hooks on the face of either the interface pad or the backing plate.
The 6" sanding discs can also be used by hand using the Meguiar's Hand Pad - S-6HP
See also...
Meguiar's New 3 Inch Professional Headlight & Spot Repair Kit
Product Attributes
- Precise, uniform grit particles for a smooth and even sanding pattern
- Ideal for removal of dirt, orange peel and severe paint defects on fresh finishes
- Sanding = No foam backing
- Quickly levels texture
- Micro hook & loop interface
Product Attributes
- Precise, uniform grit particles for a smooth and even sanding pattern that buffs out in seconds
- Finishing = specialized foam backing
- Quickly refines sanding marks & removes moderate surface defects
- Soft foam backed disc for texture matching and scratch refinement
- Always used damp – water only
- No sanding lube
Product Attributes
- No sanding lube
Back side
Working face side
Product Attributes
- Distributes pressure for smoother sanding/finishing
- Precisely tuned outer edge for ideal disc contouring over flat and curved surfaces
- Allows quick disc changes with micro hook & loop interface
- 5/16 thread for use with air or electric DA’s
Back side
Working face side
Product Attributes
- Safely follows contours and works closer to most edges
- Ideally engineered for use with Unigrit Sanding & Finishing Discs
- For use with air or electric DA’s
- Results in one grade shift upward in finish results
Intended Markets
Meguiar's G110v2
See also...
