Remind me... which tool are you using for these buses?
Went back to your bus thread, still didn't see what too you're using and I hate to assume but my guess is the
Flex 3401
Also caught this portion of one of your posts...
Swirls are not an issue, right or wrong is not an issue, white, shiny and fast are the only issues with these buses.
M85, M84 and M86 are all recommended for rotary buffers only but that doesn't mean you can't try them with a Flex 3401
What you want is something aggressive to cut the dead, oxidized gel-coat off the surface while polishing and protecting in one step leaving a clear shiny surface. In a perfect world, no swirls.
With a Flex 3401 I would try a very aggressive pad, maybe look at the purple Kompressor or the very aggressive yellow CCS foam cutting pad, or a Surbuf pad with a strong cleaner/wax.
If you increase the aggressiveness of your pad and use a strong one-step cleaner/wax, you might be able to reach you goal swirl free if in fact you're using the Flex 3401
Maybe look at XMT 360, D151, M66, M50 liquid is a time-proven strong cleaner/wax for oxidized gel-coat surfaces, it's very wet which is important when working on dead, dry oxidized gel-coat and if you increase the cut of your pad you can get some very good cleaning action out of all of these and also polish out to a clean, white, high gloss finish.
That's what I would try...
If you want to try to do it in two steps, compound and then wax, well then I'd still be trying some very aggressive pads if you're using the Flex 3401 and M95 or M91, M67, or M49, all of these are very aggressive compounds that will restore color and gloss while being low swirl.
Sounds like lots of pad cleaning in in order to as you're going to have a lot of dead, oxidized gel-coat building up on your pads as well as spent product.
A large nap, terry cloth towel will also help you to remove the residue off the surface as the large loops of fibers, called the nap, will slice into and loosen the compounding residue.
