Meguiar's Boat/RV Polish
Cheeseburger
Mike,
I would greatly appreciate it if you could tell me what Meguiar's Boat/RV Polish is doing to the gel coat and what duration I can expect the polish to last before needing to reapply. I am using a polymer sealant as a top coat.
Thanks Mike,
Eric
Hi Eric,
Thanks for taking this to the forum, behind the scenes there's so much going on it's hard to get time on the forum this week so anything I do work on it's better if others can chime in also.
Specifically, the M45 Boat/RV polish is what Meguiar's calls a non-abrasive, pure polish. Meguiar's is actually one of the few companies that makes non-abrasive, pure polishes as most either have,
  • Abrasives of some type
  • Protection ingredients of some type
M45 has neither of the above, it's a water-soluble pure polish for maximizing gloss, richness of color, depth and reflectivity. Of course these characteristics are better seen on dark colors than on white like many boats are colored.
The idea behind this product is AFTER all the compounding and polishing is done with the abrasive compounds and polishes, then you would use this product to gorge a gel-coat finish with the polishing oils unique to the Meguiar's line since 1901 and after applying this product then seal the surface with something that's not water-soluble, i.e. a wax or sealant.
M45 would be in the same category as #3, #5, #7, #81 and Deep Crystal in their Consumer Line, these are all non-abrasive pure polishes.
One of the problems in the detailing industry, including Marine watercraft is that there are no "Wax Police" and by that I mean there are no legal ruling authorities to govern the "words" used on the labels of products to standardize what's inside the bottle to mean what's on the outside of the label.
As such you'll find waxes and sealants labeled as glazes and polishes when the root beginning for glazes and polishes has it's history in fresh paint environments, not consumer or detailing related markets.
Anyway, to make a long story short, judge a product by what it does, not but the name on the label.
If you apply M45 to your boat and nothing else, any results it creates won't last long as the correct process would be to follow an application of M45 with a wax or sealant.
While the below article is completely different than the topic of our thread, I have quite a bit of information on how Megs pure polishes work...
You can find it in my article list under
Articles on Car Paint
New - Test Spot - The story behind the story...
New - How to Test for Single Stage or Clear Coat Paint
New - Audi Soft Paint - Making Generalizations about Hardness and Softness
New - Static Electricity and Dust Attraction to your Car's Paint
Camaro Clear and my take...
The Secret to Removing Oxidation and Restoring a Show Car Finish to Antique Single Stage Paints <-- This one...
Don't wax your car for at least 30 days!
Fresh Paint - But you can touch it...
Body Shop Safe Glaze on Fresh Paint - #7 Show Car Glaze
The practical differences between single stage paints and a clear coat paints
The Lesson White Paint Teaches Us
The Clearcoat Failure Photo Gallery Archive
Beginning Clearcoat Failure
What it means to remove swirls, scratches and water spots out of automotive clear coats
This article also has some information on the early non-abrasive pure polishes that have been around since the Model T and thus have been around since car paint was invented.
Some Vintage Meguiar's Products from my Collection (Lots of pictures)
Hope this helps...
Thank you! I have an RV lined up and was looking at this product. This post really helped!!!!!
