Meguiar's D114 Dilution Ratio (Math problem)
TheAverageMan
I ran the math, and need some help, or verification if I did it right. I'm okay at math, but was confused on some parts
I am getting D114 and want to dilute a 1:256, 1:192, 1:128 ratios. I plan to put them in 32 oz spray bottles. I am better at the metric system, since I find it more accurate, and easier to use with a tuberculin syringe.
I need someone to clarify my math, if I am doing it right please.
32 oz bottle = 946 ml bottle
1:256 = 0.125 oz when you take 32/256.
0.125 oz = 3.7 ml of concentrate
Now the question. I need 3.7 ml of concentrate in a 946 ml bottle, correct?
Would that mean that I subtract the 3.7ml from 946. Meaning that I would need 942.3 ml of water, and 3.7 ml of concentrate.
Like this.
942.3 ml H2O + 3.7 ml concentrate = 946 ml solution = 32 oz
Another question. What is the best water I could use for this? I have access to 5 gallon purified water that we use for drinking, should I use that stuff measured out?
As for the 1:192 and 1:128 ratios, I have these formulas.
1:192 = 32/192 = 0.167 oz = 4.94 ml conc. - 946 ml H2O = 941.06 ml H2O
941.06 ml H2O + 4.94 ml concentrate = 946 ml solution = 32 oz.
This seems complicated. I just add one ounce to 2 gallons of tap water and then fill my 32oz bottle with the solution from the bucket and use it as pre soak
I'm sure theres something to being correct with the dilutions but I think it's such a reasonable product,I'm not stingy with it at all.
Distilled water or DI water.
Wouldn't it be easier to mix them at:
- 1:100
- 1:200
- 1:250
Regards :D
Life can be made a lot easier. This is assuming you have a 1 oz measuring cup.
Just prepare gallons and watch this.
For 1:256, get a gallon of water, pour out 1/2 oz into the measuring cup, and throw that water out. Pour in 1/2 oz of Megs into measuring cup and pour into gallon. Now you have a gallon of 1:256 solution.
For 1:128, do the same but pour 1 oz.
For 1:192, do the same but pour 2/3 oz.
And that's it, now you label your three gallons of water as each dilution and pour into the spray bottle from there. Don't make it complicated.
Thanks for the replies. The calculator came out with the same answers as my calculations. And oh snap, Roshan is in here, I watched a bunch of your videos on dilution, nanoskin, and rinseless wash stuff while researching. Ill probably do what you said, and just make D114 by the gallon.
That's what I do for my 1:128 dilution of D114 that I put in my 56 oz pump sprayer.
It'll make life a ton easier, trust me :) :props:
:dblthumb2:
That's some impressive unit conversions you got going on there. I can appreciate that. Unfortunately, it's not really needed here. Dilution ratios don't care what units you start with. So I tend to make it a percent and go from there.
For example 192:1. 1ml of additive plus 192ml of water. If you mix it perfectly you get 193ml of finished product. 1 divided by 193 gives you 0.00518 or 0.518%. So now we just multiply.
You want 946ml total. 946ml x 0.00518 = 4.9ml. Add 4.9ml to you container and fill to the 946ml mark.
I hope that came across correctly. I have trouble explaining things through text.
Yeah, but that gives you 1:255 and 1:127...I hope you do better at mixing amalgam :p
Dear "TheAverageMan
I, for one, appreciate your attention (OCD-ness)
to such small details... :xyxthumbs:
Pay no attention to the:
"nattering nabobs of negativity"!! ~S.T.Agnew
They're the same ones that are at least a little OCD,
themselves, when it comes to being concerned about
the many, many other matters of detailing-details... :)
As far as I'm concerned:
your math is spot on!
•But, being a little OCD myself;
as well as being: old school...
I would have went with this conversion method:
-ounce (US liquid) = mL
-gallon (US liquid) = mL
•As such, then [when rounding-off to the fourth place;
and: using "US Liquid"]:
-1oz. = 29.5735mL
-2oz. = 59.1471mL
-32oz.= 946.3529 mL
-1gal. = 3785.4118 mL
-1.5 gal. = 5678.1177mL
-2gal. = 7570.8236mL
Resulting in the same/similar D114 dilution ratios
at which you arrived.
If you don't mind...
Besides the ones you've listed:
Allow me to add a couple other D114 dilution ratios...
that you may find to facilitate other detailing duties.
•In an ~946 mL container (using distilled water):
-256:1 = 942.3 mL water/3.7 mL D114
-192:1 = 941.1 mL water/4.9 mL D114
-128:1 = 938.7 mL water/7.3 mL D114
-15:1 ..= 886.9 mL water/59.1 mL D114 ("panel wipe")
-6:1 ... = 810.9 mL water/135 mL D114 ("wax stripper")
-4:1 ... = 756.8 mL water/189.2 mL D114 ("wax stripper")
I
I'm not familiar with your "purified" water for drinking purposes: Does that mean it's Distilled water?
If so: that's a go! :)
BTW:
I've always heard that distilled water is not as healthy for drinking-water as your tap water would be. Something about humans needing minerals and such.
(But that's a subject for a different OCD-thread)
Thank you for all the replies. I got a hold of a few things.
2x 60 ml/2 oz syringes, and 2x 1 gallon distilled water.
I also went to Home Depot and got a HDX 32oz spray bottle for 2 bucks, and a hand pump spray thing from the gardening section for 6 bucks.
Will be putting in all of your measurement advice. Thanks.
