Meguiars D4510 - Plastic & Vinyl Coating Review
Eldorado2k
Here's a quik review of a product that rarely ever gets mentioned. I figure it might be so rarely talked about that some people who are a bit new might not even know it exists.. So here it is, Meguiars D4510.
This little aerosol spray trim "coating" is quite a valuable tool to have in the arsenal as it makes those little finishing touches stand out on a vehicle. Areas like the windshield cowl can sometimes be tedious to fully apply dressing or protection to, but this aerosol makes it easy.
Spray it into AC vents instead of using a messy brush or an applicator.
But as many of you experienced detailers already know, using it to dress honeycomb grills is where this product earns its place.
Turns ordinary parts:
And really makes them stand out
Gotta love the small details that help set it apart from the rest
Underrated product. Thumbs up in my book.👍🏽
Every engine I do gets a spray of this. It makes the covers black and shiny without ANY greasy feel or look. I have at least 4 bottles at all times. GREAT stuff
how does it compare to this...
Can you spray into an applicator and then wipe on?
No, you can't. It must be sprayed directly onto the surface.
They're very different products. Personally I do not like that product in your picture^
Ultimate Black Restorer darkens faded trim, but not to the level that D4510 does... Ultimate Black Restorer goes on like more of a clear coating that dries to a extremely resilient coating that's nearly impossible to remove. [that can be a bad thing if you don't love the look it gives] It leaves a more artificial look than D4510, which is another reason I don't really like it.
D4510 leaves a deep dark look with just the right amount of shine and lasts 2-3 weeks on the surface. Smells good too.
Thanks for the review. What kind of durability do you see?
2-3 weeks. You'll notice the difference here between the top parts of the grill which have been applied vs. the very bottom piece of the black plastic grill that hasn't.
So wiping down after spraying is not necessary?
For those of you who spray air conditioning vents does the product leave any type of residue that will eventually build up and need to be cleaned with a cleaner type product?
Thanks,
Ron
Thanks. I just remember years ago using armor-all on everything and eventually the surface would become sticky and you would have to use an apc or windex to get it off only to reapply it once again. My dad use to tell me I was an idiot for spraying that crap on my dash because it would cause it to crack and he was right.
Ron
Thanks,
Ron
It's not necessary but it helps level it out nicely. A light buff will not have any adverse effect on it. It also helps to wipe off any overspray on the surrounding areas. Expect about 2 weeks of longevity.
I personally love this stuff! I buy it by the case. I also will wipe it down sometimes. Just depends on what it's getting used on. As Eldo stated, it really gets those details which make such a huge difference with minimal effort.
I think ill go buy 200 dollars worth so I can get their free crappy apron that only has 2 tiny pockets and isnt even microfiber.
@robwoodgto. This stuff doesn't exactly dry to the touch in most cases... Just sayin so you don't go spraying in on your dashboard. It's better suited for areas you won't touch.
Thanks. I wouldn't spray it on my dashboard. After my Armor-All days I am very cautious about spraying anything on my dashboard. I am kind of OCD about touching sticky gook. I do plan on trying it on my grill and cowl. I will try it on my ac vents but if it leaves the least amount of stickiness then I will either have to buff a little or not use it there...just some little quirk I have I guess.
