Meguiars DA Microfiber correction rocks!!!
Success
Member
Check out these before and after!
I scratched the top bedrail right below the bedliner. I was washing out dirt from the bed and the hose was rubbing along there. I didnt think I could fix it with a DA.
I also applied collinite 845 to there after to test it out. Wow that stuff is awesome. That is all I will use exclusively from now on.
It is a very nice system introducing some really cool new technology but a word of caution for any pad and product combination you use... and that is to first do a Test Spot on any car that you have not previously worked on and make sure the pad and product combination you're planning on using over the entire car is giving you the results you want, expect and hope for to one small section before buffing out the entire car.
Doing a Test Spot only takes a few minutes and if everything is working you have the confidence to proceed, if it something isn't working right you'll have just saved yourself a lot of time and paint.
Thanks mike! I think you misunderstood me--I plan on using the collinite from now on as my lsp
Good catch...
I read the title and the post but put together this...
Glad you like the Collinite 845
Typing too fast... thinking too slow...
:laughing:
