Crispy
- Jun 13, 2013
- 779
Have been using this product for about 1.5 years and t is by far the best buffing pad cleaner I have found.
Was original sold as a cleaner for the DynaCone metal polishing Yellow cones.
It works very well every time.
Soak the pad with couple of sprays and let sit face up for couple of minutes.
Place in small amount of the hot water (just enough to cover the pad) and let sit 10-15 minutes.
Nead the pad in the soaking solution to release the polish (will be white).
Inspect and if some stubborn spots, repeat but only need to let soak couple of minutes.
I have used it with following Polishes/Compounds
Optimum
Menzerna
Rupes
Maguiar's
Just did an 3" Orange ThinPro pad that was caked with Optimum Compound II and fresh paint-cleaned up good as when started and only took 15 minutes.
Only down side is AG has been out of product last year or so everytime I place an order for other products.
Optimum
Menzerna
Rupes
Maguiar's
