Shinystang
- Feb 14, 2007
- 36
Oh man, NOT ANOTHER PAD QUESTION!!
I've used only LC pads for both the Flex DA and the PC 7424 and have had great results, esp with Menzerna products.
I'd like to use the 9227 for more than headlight restoration and small areas of paint correction. So far I have only used LC 3" pads with Megs 105/205 and I want to try the larger 7 or 8 inch (both foam and wool pads.)
My question is there an advantage using the flat-surface Meguiar's foam pad vs tilting the rotary and using a LC beveled CCS pad?
I'd appreciate any input
