Meguiars Hyper Dressing Question
TheAverageMan
When undiluted, is it as thick as a gel?
Right now I have Endurance tire gel from Meguiars. Stuff smells like grape juce heaven BTW.
Was deciding between
D170 Megs Hyper Dressing 1 Gallon
Optimum Optibond Tire Gel 1 Gallon
D163 Megs Tire Trim Gel 32 oz
Im leaning on Hyper dressing IF its got a gel consistency undiluted.
Im leaning away from D163 cause it only goes up to 32ozs.
Optibond is up in the air as well.
Can anyone with any of these comment on ther scents? Is D163 Grape heaven?
nope. it's like a very VERY smooth smoothie. not a gel at all. i'd say undiluted, it's identical in consistency to Opti-Bond.
So D170 and Optibond gel have very similar smoothie consistency. Coool. Can you comment on their smells?
Know if 163 is thicker than either of them?
D163 is a gel. There's a thread on here somewhere. It actually lasts awhile. I still have quite a bit left.
i want to qualify my last statement - my bottle of Opti-Bond is very old. i don't use it, so...thinking back, i think it's thicker than my current bottle. it's probably somewhat more of a gel than i described. and it has no smell.
my bottle of Hyper Dressing is old too, it's lasted a while because i dilute when i fill the 32 oz spray bottle, however, if i recall, it's always been this smoothie sort of consistency. it smells like artificial grape flavor...smell. not terribly strong.
i haven't used 163. from what i've seen of it, it def appears to be thicker than straight HD.
I have used all of them.....
I would rank them in this order:
Opti-bond as it seems to last the longest. 2 application will give you the glossy look if you so desire.
Meguiars Tire and trim Gel. Thickest consistancy out of all of them. Need two good applications for that medium gloss. One application will give you a nice matte/satin look.
Hyperdressing is a smooth constancy. You won't get a long durability with this one. It's a wheel well dressing for me. I haven't tried it straight but I mix on 4:1 ratio.
Hyper Dressing is also a great (cheap) engine dressing, too. Maybe not Sonus Motor Kote good, but still very good. And on wheel well liners it's truly SOWA.
use to use hyper dressing, opti-bond and a few other water based dressings until I tried PERL and have never looked back...
I primarily use Hyper Dressing. Can be used for engines, wheel wells, and tires. I primarily use it 1:1. Has good durability unless it gets wet.
Isn't Perl a water based dressing also? It's got the same main ingredient as Hyper Dressing (they both show it as 40-70%, so who knows what the actual is). The difference seems to be that Perl has a small amount of trade secret silane in it, which I'm guessing is what makes the world of difference between the two.
I have a little sample bottle I bought I haven't gotten around to trying it yet.
The main difference is price! I like PERL, but there's no way I'd be spraying wheel wells liberally with it and walking away. At that price I dab it on a rag and do rubber window seals and other smooth trim with it, not much else.
I've used both on the engine bay. I don't like motor kote. It dried spotted. Hyper dressing dries uniformly except for a little build-up in a corner.
Ive not used Optibond or PERL.
Between the Meguiar's products
Tires & Trim only - Go for the T&T gel no question
Tires, wheel wells, interior dressing, engines - Use the Hyper Dressing you will be very happy.
Hyper dressing is my go to for engines and wheel wells. I like it at 4:1
hyper dressing or perhaps water based dressing (d-line) are great for the wells (even the engine too) and isn't very expensive when you stretch the product, but I prefer PERL for the tires/trim. i bought a gallon of the water based dressing and only use it for the wells for only that purpose since it was so cheap...
Is this going to be for personal use or for clients?
Das: Those look SWEET! I love the HD at 4:1 and 3:1!!!!!!!!!!!!!! Cant beat the low gloss look (I also agree that the longevity isnt great)
Guz, personal use. Im now leaning eavily on Opti, for the price, and size, compared to D163
I actually like D163. I just used it on Friday on my daily driver. I average about 3 weeks before reapplying. I've pushed it as long as 4 weeks.
Hope these photos help you out.
Here it is after application. This is 1 coat.
This is 2 coats on my camaro
