Meguiar's Last Touch Dilution Recommendations
theblob640
Hello all, I am currently using Meguiars Last Touch straight as a QD/drying aid. Meguiars recommendations are using it straight as a QD and 1:1 as a clay lube. Do you guys use other dilutions for a QD/clay lube? I was planning to try 1:1 as QD and maybe 4:1 as clay lube. Also, I would like to know the dilution ratios that you guys use/recommend for this product. Looking forward to your inputs.
Thanks.
Thanks for the input. Looks like I will be continuing to use as directed.
I use 1:1 for both clay lube and drying aid. I haven't used this as a QD because I have UQD and UWW+.
