Meguiars mf cutting pad on the Rupes nano ibrid
Some of the nano backing plates have had delamination problems even when used with rupes pads. The megs MF will generate more heat than the rupes foam, so be careful
The delamination of the bakingplate has happened already . Just used some epoxy glue and it sits Munch better now
I've run the LC MF pads on it, but not the Megs.
Do The lc mf pads cut better than the blue pads from Rupes that comes with the ibrid nano
