Meguiars MT300
choijw2
So i bought meguiars MT300 less than a month ago,
and used it for 3rd time yesterday....
middle of polishing, it started making odd noise from motor,
.... like something was lose inside of it.
Also i hear metal shaking noise when i turn it off and vibration is increased noticeably.
already talked to Palm Beach and sending it back for inspection/ exchange.
but I am not sure if I should get another MT300 or just invest little more maybe get FLEX 3401 or Rupes....
this was my first DA polisher after using cheap chicago rotary buffer..... which makes me little worried about this product.
anyone else having issue with this unit??
From what I've read they are still having the power cord issue that they've had fo years. This sounds like it may be a different issue. If your only going to be doing a couple cars I would probably go with a PC or GG6. The GG6 has more power and a lifetime warranty. The GG Boss machines also have a lifetime warranty. Flex is a great machine. Not for everyone though, some don't like the forced rotation because you have to muscle it a little more at times. There may be a bit of a learning curve. I have a Flex, GG21, and PC DA's. The GG21 is definitely the smoothest machine. I'm sure some more people will chime in. The Flex, Rupes and GG Boss long throw machines are all great machines. They all have pros and cons. If you go with a GG6 or PC they are a little more versatile. You can go down to 3 inch backing plate and pads for tight areas. My personal opinion I'm sure several will disagree, but I think everyone should have a GG6/PC style machine. Since it appears your fairly new to polishing I would go with one of those as a first machine, then if you get serious about detailing then you can add more machines later and have time to research both types a little more. If your an experienced Detailer then disregard this. I'm assuming from the number of posts and the question you are fairly new...
What DaveT435 said!! Can't beat the lifetime warranty and excellent customer service from Griots!!
Meguiar's customer service is great as well. Their warranty needs an overhaul with this machine. 1 year is not going to cut it.
Neither is the 30 day return policy I've read about, and then you have to pay shipping both ways and repair costs too. Someone correct me if I'm wrong, but that's what I read somewhere.
I have a G110v2, but will not own another Meguiar's unit until they fix that return policy. If it has a year warranty a person shouldn't have to pay anything to have it shipped either way, or to have it repaired.
Very true about that. Which is why I said they need to work on that 1 year warranty to cover everything.
I don't know about the 30 day return policy and whether that is true or not.
Having to pay shipping for returning a product for repair is standard all manufacturing companies. The companies that do not charge the shipping fees or cover them are the very rare exceptions.
Meg's is prone to have their machines not working, get a Rupes. Problem solved.
I will never ever, ever buy a Meg's machine.
Forced rotation from my understanding means that the backing plate is directly connected to the drive mechanisms and spins in direct relation to motor speed. It is forced by the motor speed, therefore it will never stop rotating. The only forced rotation dual action polisher that I am aware of is the Flex 3401.
All other dual action polishers have some sort of a free floating spindle design. This means that under pressure, the spinning will slow, or stop. This is what makes DA's so safe to use for most people. The spinning of the pad is not directly related to motor speed.
I think I got it there ;)
Can someone elaborate on what forced rotation means? Thanks.
well short answer is, you can't stop the rotation no matter how hard you press.
I kinda think of it as hybrid unit of DA and Rotary polisher.
when you have Griot's with a lifetime warranty and the PCXP with a 3(?)year warranty, they should set the MT300 warranty around 2 years at the least (gives the buyer a little more security) especially given the price is a little higher too. the most casual user may only use it 3-4x a year...
No point in spending 210 dollars your half way there fork up the extra cash and get the flex, rupes , or boss ,you won't be sorry
The flex is dual action as well like any da but its forced rotation meaning it has a gear drive that causes the orbit.
Its not free spindle.
In example if you get a porter cable and spin it. You can spin it left or right and it spins like a wheel.
The flex has a gear that drives that its not free spindle so on concave areas or curves the machine won't stop rotating ever.
