Meguiar's Ultimate Wash & Wax Anywhere
TuxedoTaurus
I have never done a Waterless wash. I was always skeptical of the safety of the paint with them. Well last weekend I took a short trip to visit family and got home around 9pm. The trip was 4 hours each way, so needless to say I was a little wore out. The car was plastered with bugs and there was no way I was going to let them sit there. I went to the local Auto parts store for some washer fluid and saw this product. I figured I would give it a whirl after running the car through the touchless. I planed on using this as a drying aid for the drips left behind.
Before going through the touchless I sprayed the front end down GG Bug remover, let dwell, then pressure rinsed the whole car. I proceeded to go through the touchless and pulled into a bay. I grabbed my MF towels and started to spray the product. The initial wipe was silky smooth, but what reall caught my attention was the Buff off. The towel almost slid out of my hand the surface was so slick. So I decided my next wash would be waterless with this product.
About the Product: (Taken From AG Store)
Meguiars Ultimate Wash & Wax Anywhere safely lifts away dirt and grime while leaving behind a protective layer of hydrophobic wax. In as little as 15 minutes, this waterless wash plus wax formula can morph a drab and dirty appearance into a stunning, clean and shiny car, without a drop of water. What's more, depending on how dirty the car is, a single bottle of Meguiars Ultimate Wash & Wax Anywhere, along with the help of a few microfiber towels can wash & wax up to five average sized cars.
Meguiars Ultimate Wash & Wax Anywhere is perfect for urban dwellers, those with limited access to water, or the hot rodder that just arrived at a cruise. With this product, you can clean and shine any vehicle. Most waterless washes do a good job of cleaning but leave no protection. Most quick detailers add shine but offer little cleaning ability. With Meguiars Ultimate Wash & Wax Anywhere, you get it all!
Meguiars Ultimate Wash & Wax Anywhere is a quick and effective alternative to traditional car washing for people who don't have regular access to a spigot or the space to wash a car.
To use this spray, simply mist onto the surface of the vehicle and wipe away using a Meguiar's Supreme Shine or other high quality microfiber towel. Ultimate Wash & Wax Anywhere's unique chemistry ensures a scratch-free finish when used as directed, as special lubricants and cleaning agents safely loosen and then gently remove the dirt. Follow with a quick wipe from a clean, dry towel and the surface is left with a beautiful, glossy, just-waxed finish. Ultimate Wash & Wax Anywhere is also safe to use on all wheel types, plus rubber, vinyl and glass.
Meguiars Ultimate Wash & Wax Anywhere is a very worthy addition to any car enthusiast's detailing arsenal
Before:
Apply Product:
Results:
After finishing the car I took a used rag and wiped the wheels
And a better sun Shot from a previous day after using
Pros:
Extremely easy to use
Does not streak even in full sun, just work smaller sections
Pleasant Pina Colada scent
Excellent cleaner even on road gime
Leaves paint slick and glossy
Cons:
Price - at $12 a bottle it is a rather expensive car wash ($3-$4 a wash)
Conclusion:
This product(or if a Bulk version is available) is a must for traveling. It did not harm the paint whatsoever. It was a pleasure to use. I am curious if the D115 is the same product in bulk form if I can get a confirmation on this I will be buying some ASAP!
I will also like to find the Mothers new one locally to compare.
On 07.12.2013, Mr. Michael Stoops
said the following:
"D115 is the concentrated rinseless wash
and wax you've been asking us for.
Many of you are already familiar with and
love our Ultimate Wash & Wax Anywhere,
but wanted a larger size,
and D115 is essentially that product.
The concentrated formula stretches your
dollars even further".
____________________________________________
said the following:
Thanks, Bob.
Looks like D115 will be ordered and maybe some D114.
This is certainly good stuff. I will add that the protection works pretty good as well. I used it as a test presoak on road salt last winter on one spot of my door. The leading edge of my door stayed consistently cleaner throughout the winter.
That's how those water-fearing (Hydrophobic) polymers...
that's added to its formulation...are intended to perform!
I'll lay odds that you'll wind up loving
both of these Meguiar's products!! :dblthumb2:
I have a similar feeling.
With this and mothers waterless tire cleaner, I might not bring buckets when I take trips.
I use D115 a lot and it is damn near bulletproof. I also love D114, especially on coated vehicles. FWIW, I use D115 at 1:10 and I find that it cleans just as good at 1:4.
D115 is worth every penny. Its that good and works great at 1:10.
That makes it around $6/gallon which is pretty good actually. I'm definitely buying some when I run out of Opti-Clean.
