Eldorado2k
- Nov 9, 2015
- 14,480
- 584
Hello everyone
Lets get right into it...
So I’ve been meaning to do a somewhat major decontamination on the Kia after it somehow ended up with a ton of overspray a couple of weeks ago.. I decided to hold off on doing it until I had some kind of iron decon to use as a pre step and it was a good time to check out this new product from Meguiars.
https://www.autogeek.net/meguiars-ultimate-all-wheel-cleaner.html
I started very early in the morning and the vehicle was already wet from the condensation, so I went ahead and gave it a good rinse, then sheeted most of the remaining water off the paint. Then I sprayed every panel with the Megs Wheel Cleaner.
The bottle only has a single on/off setting which sprays somewhat in between stream/foam, but more towards stream. It sprays clear liquid and I couldn’t detect any scent at all.
This is what the roof looked like about 5-6 min. after it had been sprayed.
Here’s the hood after 5-6min.
Sides of the vehicle... Must’ve been free of embedded iron contaminants, because very little color changing happened here on the sides.
The rear saw the most color changing at the 5-6min. mark.
I sprayed the vehicle off with the hose and moved onto the next step...
But before I did I decided to spray 1 of the front wheels just to see if there was any iron contamination on it.. These wheels are maintained with Meguiars Wheel Brightener.
Sprayed.
After dwelling for 6min... No iron detected. Looks like the Wheel Brightener is doing a fantastic job of keeping the wheels perfectly clean [touchfree to top it off]
Final thoughts after my 1st use.
Pros:
It’s odorless
It’s very economical [$8.99 per 24oz]
Cons:
It’s clear liquid, which makes it slightly difficult to tell if you’ve sprayed enough on a panel [this isn’t really a factor when used on wheels]
It would be nice to have different spray options instead of just 1 setting.
Maybe it’s just me, but I went through alot of it compared to when I use DUB Wheel Cleaner for the same purpose.
Sprayed.
Pros:
It’s odorless
Cons:
