Hi all
I am in the process of purchasing a DA (12mm throw) as well as some Lake Country SDO pads (based in Australia) for use on my black car.
The car is a black Hyundai Nline 1.6T and i believe the car to have soft paint. I could be wrong (like i am with most things in life), but from what i can tell the paint seems soft.
The pads i am buying are a few of the black (finishing) and some orange (polishing - intermediate). I don't think i need a cutting pad at this point.
From what i can see the swirling is minor to moderate. Car is only 10 months old and the dealer didn't touch it (as instructed) and its been hand polished a couple times with Megs UP. I am also quite vigilant with my washing process.
My questions revolve around which which product/pad/speed to use.
Product/Pad
From other posts on here ( and other forums) it seems that for order of aggression the products go UP - Scratch 2.0 - UC. I have all these products at my disposal.
I was going to start with UP/Black pad then move to UP/Orange and then make my way up in product aggression along the same pad pathway.
Does this sound about right? I know UP is very minor in terms of aggression but it does contain some correction ability and matched with the right pad it may just remove some light swirls?
If i have to use Scratch 2.0 - can this product be used on the whole car (it seems to be marketed as a spot correction product) and is it likely i'll have to then finish off on UP or does Scratch 2.0 finish up nice enough on its own?
DA Speed
In terms of speed I've not really found much info around this. The machine i have has the following specs i think: Speeds 1-6 (
Wax: 2-3
Polish/finishing: 3-4.5
Correction:4.5 - 6
Therefore, if I'm trying to get some correction out of the UP/Scratch 2.0 i'd hit that with 4-5 and see how that goes at maybe 3-4 section passes?
Thanks in advance for your help!
Product/Pad
DA Speed
2500-5500/rpm)
In a general sense would the below assumptions be correct?
Wax: 2-3
Correction:4.5 - 6
