ctfshjohn7
- Jan 25, 2021
- 4
MEGUIRES COMPOUND VS 303 COMPOUND VS CHEM GUYS WATER SPOT REMOVER
i have some water spots ( etching ) i notice once i park it in a garage with over head lighting.
i believe i may have sealed them in with the last wax / graphene.
i need to remove the layer of protectant i believe before i use the chemical guys water spot remover.
so i have questions
1. which compound is lighter in abrasion of the 2 i have ?
2. hoping this process with a compound will remove the spots , and i wont need the chem guys water spot remover ,
is this wishful thinking ??
any advice or thoughts??
3. have you used the chem guys water spot remover ?
i have water spot etching on the silver plastic trim as well, and am reluctant to use anything on those areas , other than polish / wax and that doesn't seem to be removing the etching spots.
also skeptical about using it due to people telling me subaru has " soft paint ".
2019 subaru- crimson red pearl paint btw.
just purchased a year ago and don't believe prior owner was critical of the vehicle surfaces like i am.
thank you in advance for any help on the situation, it is appreciated.
:buffing:
so i have questions
:buffing:
