Menzerna and humidity?
matteo86
Quick question. Theres an overcast...but the weekend is the only time I have to polish. It is about 10-15C and the humidity is 94%. From experience is it worth trying out SIP and 106FF today, or should I wait it off for another weekend?
Thank you.
Thank you.
if you have any Opt polish just add a drop or 2 to the pad with the Menz and it will help it from going bad on you....
AL
AL
Thanks for the response...you think like PB SSR1 would do the same? I got the PB line and menz SIP/106ff only ;/ ?
I am not sure about the PB SSR's with menz...so can not answer that....but I have read that a few have used the Mothers Power Polish with Menz to keep it working longer and less dusting and worked for them....
you may not even have a problem..so try it first to see what you encounter....
Al
