Menzerna One-Step Polish 3IN1 how agressive is it (using on 3 year old car)
wantboost
Member
I will be using a handjobber i have yellow and whitw pads .
I'm a newbie here I'm kind of afraid to use the Menzerna One-Step Polish 3IN1 on this fairly nice paint cause it says it has a compound in it?? I also have Poorboy's Polish W/Carnauba Wax that says it will remove swirl marks... so I'm curious what u guys think... it's for a Lexus which has a soft paint or clear??
I used the 3 in 1 on a ratty black Hyundai for a 1 step and it came out great with oarnge cutting pad
The only real sujestions I can tell u is to do a test spot start with soft pad and work up to a harder pad if u need it..
hyundai had soft paint..
Am I reading you are doing this by hand? If you are, you will have inconsistent results at best. Oh, and your arms will fall off.
I wonder how it compares to HD Speed or Griot's One-Step Sealant?
Menz 3 in 1 can have pretty good cut and leaves a nice glossy finish. When working by hand you won't see the products full potential. Same for the Poorboys product, cuts less than the Menz. I wouldn't want to do it by hand,
Suggest getting a DA polisher. You will get better results. Cheap Harbor Freight is about $50. It's not great but adequate. Better yet get Groits or Porter-Cable.
Then polishing becomes fun and not arduous
agreed, if money is an issue (if not get the GG6) get the HF DA and buy the backing plate and pads here at AG. interesting video on the HF DA, not as cheap as some may think. go to youtube and watch the video ---> " Teardown: Harbor Freight dual action polisher review "
I found the Menz 3 in 1 to be a medium cut AOI. If you are looking for less cut the Britemax AOI is a good one.
Funny thing about the HF unit. That thing is a workhorse for as cheap as it is. I bought one while in Florida on vacation to work on my parents vehicles. I got put on the spot last time to detail a Mustang that was inherited. I only had the HF unit. I use IGL coatings so I called my guy, got a Kenzo kit ordered, Americana pads from them as well. I have no polish, no towels, nada. Went to Autozone and got a Mothers paint prep thing, Griotts correcting compound and some cheap towels. Total budget detail, I spent $240 or so, $160 of which was the Kenzo and turned this thing out:
By hand not that aggressive. Well on a ferry cloth towel it will be some what aggressive lol
By hand I just suggest trying to cover what you got now with something like Prima amigo. Pb Black hole etc. nothing wrong with using an AIO by hand to fill the issues some.
does Poorboy's Polish W/Carnauba Wax have any cut? I'm doing by hand cause that's what the person prefers
The poorboys and menzerna products you have are more or less going to act like a wax/sealant if applied by hand. And lmao who would prefer hand over a machine??!!
To give you the answer you're looking for, 3 in 1 is about a 6/10 and poorboys pwc is maybe a 3/10 in terms of cut but neither will do much by hand of course.
I wouldn't even attempt this job by hand unless you are a glutton for punishment and/or this person has very low expectations.
even using a yellow pad vs white with handjobber wont make a difference?
I can't imagine doing a vehicle by hand, regardless of the pad. You won't be consistent with pressure and passes. You might be better off using a filling glaze by hand and calling it a day.
The filling glaze will fill more swirls than the poorboys polish w carnuba?? I already have this product that's why I'm asking and I don't mind applying by hand....
I am not familiar with the product and can't recommend a glaze except for Megs Show car glaze. From the product description what you have should work just fine! Description does say it should be used for dark colors.........
I guess I'm just being paranoid with the pb polish w carnuba im in newbie and don't want to damage this soft paint
