Menzerna Outside Temp
YankeeFan
Just curious, will temps in the mid-80's affect using Menzerna? Had an issue this weekend, stopped polishing my daughter's car as the polish would dry up quickly. Had no opportunity to work it, at all. Car is under a canopy and sat for over an hr out of the sun before I started. Will try again in 2 weeks.
Thanks,
Howard
A spray of water or quick detailer helps polish stay moist and extend their working time
Sent from my SM-G955U using Tapatalk
I use it all the time down here in Tampa with extremely high temps without any issues however we also have relatively high humidity along with the heat so that may be a contributing factor. Well, in maybe keeping it workably moist.
In my experience using less product works better when it comes to Menzerna.
RSW
I spritz my pads with Meg's M34, and use minimal amounts of product. Usually Menzerna is pretty forgiving in the warmer temperatures. Colder they're more finicky.
Okay, thanks for the help. I probably erred by starting too soon. Will have car under canopy, then wash it to give it a better chance to cool down.
Darren from Auto Fetish cools the panel down by draping a wet cloth over it, then proceeds to polish - with Menzerna.
