menzerna polishes.
jamores23
im looking for some preferences on speeds using a rotary and a DA on
1- sip
2-106fa super finish
3- po85rd.
what speeds and techniques do you guys use?
I don have any experience with a rotary but with the DA I suggest speed... Speed is needed for correction. You have to break down the polish and correct the paint.
I use speeds 5&6 for SIP
For 85rd I use 5 but as I finish the section I will slow my speed a little.
Once you get some experience you can adjust your technique to get the results you want. A lot of times I don't pay attention to speed. I look at my results and adjust my technique to get the results I want.
Rotary
Sip - 1800
SF 1500-1200
85RD 1200
These are general for me. Pressure is the key. Heavy at first then lessen. It is the key to using these polishes with a rotary IMO.
DA 6 or 5 again changing pressure is very key.
yeah i rather use the rotary with menz i seem to get better results with it.
I got excellant results with 85rd at a notch over 5 with my PCXP.
A good range is 1200 to 1800rpm for rotary or 4.5 to 5.5 for DA.
If you just want to use one speed then 1500rpm for rotary and 5 for DA will work.
As for arm speed and pressure; it is highly dependant on paint type and defect.
1- sip
3- po85rd.
