Menzerna Power Lock Polymer Paint Sealant Question
Camaro2010
Member
Just put Menz Power lock sealant on my car and need to know the drying time? 12-hours? before I can put a wax on top? Also I believe that once you put this one and let it haze for a few minutes you can wipe it off. Is there a preferred drying time prior to wiping it off?
It definitely won't take 12 hours to dry. 30 minutes should be more than enough drying time, and 12 hours to fully cure before topping.
I was wondering where did that 12 hours of cure time come from? Did Menzerna recommend this themselves?
sealants need curing time of 8-24 hours for best durability. We use it as a basis, but also consider the environment in which you apply and remove it.
