Yes. Most if not all the Menzerna polishes can be used with a dual action polisher.
Last weekend I used Menzerna Super Intensive Polish and Menzerna Super Finish with my Flex 3401 to do a car last weekend and they worked very well....rops:
What pads did you use? I've been thinking of trying these on my car? Think they're the best? What number on the finish glaze?
I really like Menzerna products. They give me a bit more control over cut aggressiveness and gloss. Menzerna PO85RD is the finest polish I'm aware of with the ability to correct 3000 grit sanding marks leaving a mirror finish behind.
Menzerna Super Intensive Polish - I used a Lake Country Orange pad to start and then switched to a White pad to finish. While Menzerna Super Intensive Polish isn't the lines most aggressive it has a fairly good cut to it so when used with an Orange pad it possesses good correction ability.
Menzerna Super Finish - I used a Lake Country Gray pad. This cuts quite a bit less and when used with a gray pad I can really make the finish super glossy. You can start with a White pad and finish with a gray or blue if desired.
Menzerna Finishing Glaze - Use a Blue or Red pad when applying this product
So, just to be sure I'm getting this right. PO83Q, then PO85RD, then APO-60? Reason I ask is they have the PO106FA which they call the super finish. I have no experience with these products so I really appreciate the info.
A couple birdies at Detail Fest informed me that PO85RD and 106FA are nearly identical...things that make you go hmm....
I have a question about Menzerna PO85RD3.02. I have been using Menz 203S to clean up the paint on a 2008 dark blue Ford Truck. This was suppose to be an all in one product.No problem at all, I'm glad to help when I can!rops:
I should have listed the product numbers along with the name to make identifying them easier.
Here's a handy chart that shows the product name, number, and recommended pads..
Pay particular attention to the cut and gloss ratings. These allow you to fine tune your plan of attack.
Menzerna Super Finish PO106FA is a great product with light to moderate correction properties but leaves a high gloss when finished.
Menzerna APO60 is what I'd call Menzerna's one-step product. This cleans and removes slight oxidation applying a finish protection at the same time. I would put this in the same category as Klasse All-In-One or Meguiar's D151.
Used a green pad and a orange pad with Porter cable. The paint has rids in it that are not coming out. I need something more aggressive. Is PO85RD3.02 a good choice?
Not trying to hijack the thread but I tried this according to the chart. I'm brand new to polishing so it could be something I am doing or maybe normal. It seemed like it came out hazy and when I tried to wipe it off it also seemed greasy. I used a white pad for power finish and then a grey pad for superfinish.
Here is a not so good quality picture.
