Al-53 said:yes...it will work....just may take more product in the long run..but the cut is the same.....
like I said..a little Opt polish and you have just about the same as 85Q...
Plus if you going to use 106FF...try that first before you use 91E...be surprised how much correction you can do with 106FF with a right pad...
Al
matteo86 said:Thanks Al, i will try the 106 first with a white LC...and see what she can do..
you have helped alot thanks![]()
