If money wasn't an issue would you take the Metabo over the Flex?
Pros and cons?
User friendliness for both?
TIA,
~Goose
You hit the nail right on the head. I'm basically a moderate detailer, I wouldn't say occasional because I can get tons of jobs, however, I'd like to be able to offer more than what somebody in my position would be happy offeringEasy Answer, it depends! Are you a pro detailer detailing for a living? Metabo.
Are you a noobie, novice, or occasional/moderate detailer who basically does swirl removal and polish? Flex.
Both are interchangeable, but the Rotary is a heavy duty item that requries a lot of skill to use but is the industry standard.
However the Flex is blurring the line between Amateur and Pro.
Give it a try with 6.5" pads and you might find you won't miss 5.5" ones as much as you do when it comes to PC. ... and if you still want to use 5.5" pads what is stopping you? bp is 5.5".... as I like to use the 5.5" low-profile pads a lot
DA is what I'm talking about. What's the rotary version like?if money is not an issue, - get both.
By the way, are you talking about Flex DA, or rotary???
I'm very particular in having a good finish, and having to settle for what my PC can only do, bugs me sometimes. So I'd like a little more correction power over my PC, without having to get a pro-rotary machine. That's the best I could explain it...
For what I've read so far, it seems like the Flex fills the bill, but still undecided because of the pads option, as I like to use the 5.5" low-profile pads a lot
In my case I found Metabo user unfriendly so Metabo vs. Flex would be Flex, period. However, if we rephrase that question to "user friendly high quality rotary vs. Flex" answer would be "It depends". Do you have time and patience to practice rotary until mastered? Then get rotary. Is your answer to previous question no, and you would rather get the job done quickly with less chance of headaches, so you can go back to your favorite pastimes, or you need to get job done until you do master rotary? Get Flex. Are you a pro that does have mastership of rotary but wants something that can be good enough for majority of cases so less chance of things going wrong, or wants something that can take out halograms when having one of those days? Get Flex.
More precise quote of my words, if I remember them correctly, not in the mood to search, would be "used for few hours or so". That was enough for me to form an impression of it.I thought you didn't use the metabo you had.
My two additional objections were: No speed trigger (no trigger feathering) and compromise made to achieve short length (elimination of handle exerts more load on palm and fingers).I myself have the metabo and the only thing I don't like about is the speed control dial is on the bottom compare to other rotarys where it's on the top.
You may be right Porta. I was looking at the FLEX LK603VVB Circular Polisher and I may just order that one. I still have my PC which I may just have to use it with my 3.5" BP for small areas, since I figure I can still use the Flex Circular Polisher to apply sealant and such with itEasy. Learn how to handle the rotary and you will be very pleased. Cuts faster and gives a superb finish.
So, final advice... Flex DA or Flex Rotary?
Feed back please
That's the kind of feedback I wantUmmm, wasn't that feedback (Flex DA vs. rotary) already given?
If you do end up leaning to rotary as final decision you should rephrase the question into "Hitachi or Dynabrade". As much as I like Flex DA I am not impressed with Flex rotary. It starts at 1000 RPM, weighs pound or so more than Hitachi, and has one year warranty (while Hitachi has five) while costing $75-ish more than Hitachi.
Are you sure? LOLOriginally I was thinking DA, then the more I read, the dumber I get, but I should stick with my guts here. Flex DA will be my final answer :cheers:
