I recently was donated one of the above mentioned random orbit sanders... I'm wondering if it will work for minor paint correction and swirl removal? Here's some pictures.
This picture shows the "duo" function... basically the orbit has 2 settings; one more aggressive than the other. Which one should I use?
It also has a variable speed control with speeds from 1-6.
And here's the website.
I'm guessing the first thing you're going to say is how heavy it is... I'm aware that I'll probably be getting a good workout if I end up using this thing! But it was free to me, so I'll take the workout. I'm not exactly sure where this fits in the "How to pick the right polisher" article... I think it is a free rotating spindle, because you can grab the disc while it's running and stop the rotation, but it still orbits, if that makes sense. I removed the backer pad and revealed a center, offset bearing surrounded by a larger disc with a counterweight on one side, so I believe this is what I have.
Thanks in advance for the help!
