MF Kit Backing Plate Work With Pads?
StockDC2
Hello, I have a question regarding regarding the backing plate included with Meguiar's MF Kit. Will it work with normal foam pads from companies such as B&S?
Thanks so much in advance :props:.
Yes it will I use to have that backing plate till I got the one with holes in it.
Awesome, thanks for the reply. Can I ask why you decided to switch?
Cause when using MF all the time heat is a big issue for MF pads and the backing plate with holes keeps the pads cooler.
