Did you get the Eurow yellow towels or the Kirkland dual nap golden towels? Just asking as I've used both, and love both for their cost. Actually the Kirklands, being dual nap have a lot of uses. Be aware, WASH THEM FIRST (both types) and then the tags come of easier.
That out of the way. Use them when they are in their virgin state as you feel comfortable. Using on paint can, and WILL work unless the paint is stupidly soft (as some are) especially the gold Kirklands as they are pretty soft.
I grade all my towels that are not "high end" or "paint only" towels.
Once you use them, set aside three bins in your garage and toss them into the bins after they are used, GRADED accordingly. Paint then interior/jambs then wheels. Anything less is exhaust and undercarriage and should be in a rag pile.
I just take a marker and put a small line in one corner. Zero lines mean they go back on paint. One line means interior/jambs. Two lines means wheels (or less). Simple and to the point. I pick up a towel with no marks on it and its safe for paint, 1 mark and it never touches paint, 2 and well you get the idea.
As you use towels always grade them, always keep an eye on condition. Grading doesn't mean you ONLY use the jamb/interior towels on your interiors, just that THAT towel has already been looked at, WHEN IT WAS AT ITS DIRTIEST POINT so that you know where it was and what it last did.
Also you want to wash each grade all by themselves. For good towels you want to run a load through your washer before ever putting them in. With that in mind I start with the worst ones and do a load, then the next cleanest, next cleanest and so on. By the time you've done the other ones the washer will be ready for the cleanest ones. PLUS, you don't get yelled at by your wife when she puts a load in and it's the very next ones after you've washed something really grungy.
You're towels will appreciate it, and you're wife will appreciate it.
And as we know... if Mama ain't happy, NOBODY ain't happy!
rops:
