I'm in the process of posishing a new paint job on my motorcycle. I color sanded to 2500 grit. Followed with orange CCS pad with Meguires Med Cut then white pad and fine cut followed by gray pad and No.9 swirl remover. The parts are coming out good except I noticed after using the No.9 I still had some scratches. These scratches were not circular (I'm using a Makita circular polisher) but in a straight across pattern (the same as I wipe off the slight haze that remains after using the No.9). I couldn't figure out where these were coming from and then I thought maybe it was the rags. So under very bright light (which is how I'm doing all the steps) I wiped with light pressure in a X pattern to see what would happen. And to my dismay I discovered that it was the towels leaving the scratches. I'm carefull not to cross contaminate the towels (use a different one for each compound) and these were clean towels. These are the green and blue towels that came with the CCS 7.5" and spot buff pad kits. Are these the wrong towels to use or is my technique off. Any ideas why this is happening? Thanks.Feed back please
