GK Auto Spa
- May 23, 2010
- 193
What solution you guys use to wash your micro fiber towels? ...& where?(you home washer/dryer or the local laundromat)
OK question guys, I have a High Efficiency front loading washer ( The kind that cuts your hand off if you try and open it during the entire wash ). No, Just kidding, but it does lock the door because it's a front washer. I can't add vinegar during a wash.
Does anyone know if it's ok to use Pinnacle-Micro restore or DP detergent in a High Efficiency machine?
From what I've gathered HE just means less water....much appreciated!
Also means less agitation, giving the reason for the HE specific (low foaming) detergents that have to rinse clean easily. I think they are pretty similar to MF detergents so you should be fine, but I'm not a HE washer technician, so take that as you will.
Mrs. Old Tiger has an HE machine. I use Pinnacle MFR. I add white vinegar where the fabric softener is normally poured. Works great. I always double rinse. Only add 1 oz of PMFR. I use a quart Pro Blend to dispense.OK question guys, I have a High Efficiency front loading washer ( The kind that cuts your hand off if you try and open it during the entire wash ). No, Just kidding, but it does lock the door because it's a front washer. I can't add vinegar during a wash.
