After buying a set of Edge 2k pads and 3 grades of XMT Swirl Remover I decided to do a test spot yesterday on my single stage black 92 MB 300E with my new PC. After the first pass with an orange pad and the Fine Swirl Remover I noticed some micro marring; tiny little curved scratches which gave the finish a slightly hazy look. I went over it again with a blue pad and the Ultra Fine Swirl Remover and this appeared to get it out, but I'm curious, is this what I should expect or did I do something wrong. I'm thinking I may have buffed it a little too long, though I only did about 5 or 6 passes, maybe 3-4 minutes. I seemed that the polished had already flashed. This was in the late afternoon with the sun already below the horizon, so the surface was cool. I did forget to first spray some pad conditioner on the pad. Could this be part of the problem?
Thanks for any advice.
