I think the best way would be to test them out. Spray a QD on a panel on your car. Gently wipe the towel over the surface, and if cleans the surface right up, then your good. If it just smears, then they are shot.
You may be OK Bill. I'm no expert by any means but guys have posted that after using a fabric softener with their MF's they put them in boiling water for 5 minutes. It will release stuff into the water so when finished pour out the water. If you pull out the towel first it will reintroduce the stuff floating. Wish that I could remember who posted this??????? Good luck.
You might even have to wash them twice in Micro Restore...
I have a friend who borrowed a few of my MF towels, washed them, and yes, used fabric softener. Had to rewash them later myself.Did that......thanks......luckily i had just bought another container....![]()
a wash or two with some cleaner or a cup of vinegar should help.
how much vinegar would you put into a med sized load to soften MFs?
You have learned well Crasshopper
