Microfiber Drying Towels - Best and Boiling Towels
MI Mike
I have a two part question:
(1) Which is a better drying towel? Cobra Guzzler Waffle Weave (80/20 fiber blend), or the Blue Waffle Weave Drying Towel (70/30 blend) ? I am looking for comments from users and AG staff.
(2) Also, there has been various discussion about boiling towels to clean and return softness. What process was used? Please explain. (e.g. bring water to boil, place towels in water for ? minutes, allow to cool and dry). So what's your process, etc. Thanks.
Feed back please
I have some of the BLue waffle ones and to be honest they suck. I can dry a car faster(about 75% faster) with a old school shamcloth.
I think the guzzler and guzzler HD are both awesome drying towels. The blue WW towels have yet to impress me. Maybe after a couple washes they might absorb a little better.
I don't know about boiling the towels, but I know that the microfiber cleaners sold here work very well in the washing machine.
I love the original green guzzlers. I find no need to boil. I use the dedicated soaps (Microrestore, DP) as directed and thats all thats needed. No need to add this or that ...
Is the idea behind boiling towels to "melt" the dried on product, so it will come out of the towel?
I see some people recommend using cool water to wash MF, but others say to boil them... Can anyone shed some light on this? Or does it not even really matter?
The idea is to remove trapped waxes and polishes in the fibers.
Good question.
I have a Cobra Guzzler HD Waffle Weave Drying Towel and I need to clean it, so I'm really curious to know how I should clean it.
I already have a DP Microfiber cleaner, is it good for my Guzzler ?
I dont like the blue ones either, I like the Gold Plush, one large & one small will dry an Escalade!
Thanks for clearing that up. I've been using "warm", but next time I will try "hot"
I've never boiled microfibers in my entire life. Sometime I'll start the wash cycle over again after the first rinse cycle and on both cycles use hot water.
I had put my car towels used for washing, detailing and occasionally towels used for final buffing on newly waxed areas of my car. For a long time I put the towels in the washing machine with hot water and various liquid detergents - that worked fine on the towels. :xyxthumbs:
However there was that day where the wife dragged me over to the washing machine and pointed out that the inside of the machine was covered with a layer of dirty looking wax! The wax came off the towels and most rinsed out with the water but gradually over time thin layers of wax built up inside the entire washing machine. It was a pain in the _____ getting the hardened wax out of the machine.
That incident also remined my wife that our washer and dryer were getting up there in age and ultimately let to buying a new waher and dryer! So, proceed with caution when you wash towels that may have wax on 'em!
:rolleyes:
Green waffle weave guzzlers; They are the ultimate!!!!!!!!! I always wash all my microfibers with gentle fragrance free HE laundry soap in the washer with hot water, extra rinse cycle and let air dry. No problem!!!
I've been using either cold or warm water for the wash (along with Pinnacle MF wash) and the delicate/cool setting on the dryer all this time.
I thought you had to baby these MFs in order not to have their fiber structure melt or harden or whatever.
Hi
Do you guys wash these microfiber drying towels every time after you use them?. I do. I wash my Guzzler HDs in cold/cold with DP microfiber cleaner but I don't know if this is good or not or do you think it is better to rinse them in clean warm water after every other use and air dry?
Hi
Most microfiber care labels usually say warm wash / low heat dry. If your towels are absorbent and clean, your towels will probably last longer.
And when you use DP Microfiber cleaner in the washing machine, you're supposed to only put water + DP soap, right ? No other soap ?
Thanks.
Thanks.
Right. I used 2 to 4 ounces per the directions on the bottle.
I've washed a zillion microfibers on the hot setting and never seen anything melt. Hot water helps to soften dried up crud as well as helps your choice of soap or detergent to do it's job better.
I can get my hands cleaner after changing a dirty start motor out of an old Ford using soap and hot water than I can using soap and cold water. (Chevy starter motors never go out so I had to use the Ford analogy).
Of course, most home water heaters can be adjusted for water temperature so that's a factor that can affect how hot your wash water gets.
It's important to do what you can to get your microfiber towels clean but don't get to D.O. over it, I've worked on a lot of very nice paint jobs using microfiber polishing cloths the are simply washed and dried over and over and over again.
Here's a tip...
I'm sure you all do this but just in case, before adding your microfiber polishing cloths to the washer, first set the water level a little lower than you need. Next add you soap or detergent and let it thoroughly mix with the water after the fill level for the setting is reached. This applies to liquid soaps and detergents too....
Now after the soap and water solution have thoroughly mixed... now add your microfiber polishing cloths and then reset the dial to the water level you actually want for the size of the load you're washing and also reset the time to maximize the washing or agitating cycle.
Don't simply put your microfiber polishing cloths into the washing machine, dump in the soap and then close the lid and walk away. By the time the soap completely disperses into the water and creates a thoroughly mixed-up washing solution the washing cycle could be mostly over.
Take a few extra minutes to create a powerful cleaning solution, then add your microfiber polishing cloths and then reset the time for the right amount of water and maximum time for agitating/washing.
