A few important things, regardless of product is priming the pad. After mf pads are properly primed you can use much less product on subsequent sections (2-3 pea size drops in most cases). Cleaning with compressed air after every section is a must. Its not optional. Otherwise, product will build and gum up and the extra heat generated by mf pads causing that "baking" on problem.
Another random issue i came accross is that you must completely dry these pads before using. Excess moisure in the foam causes most products to gum up and bake on more.
I like using d151 as an aio on a cutting pad. But, the pad must be bone dry and the product must be uses sparringly or it will set up on the paint like diamond infused concrete.
Another thing is that i dont think people give the d300 and 301 the credit they deserve. You can get mind blowing results. The finishing wax is insanely easy to remove when used properly.
I think most people just assume that these are cheap production oriented products but they are not.
I was able to attend a megs training seminar a while back and i watched rod craft get insane results with mf pads and d300/301 on a trashed hood they pulled out of a body shop dumpster.
Anothee trick i found: m100(pro speed) on a mf pad, in many cases, will pull out 3000a grit sanding marks almost lsp ready.
