Microfiber Towels (and pads too!): Cleaning and Maintenance
smriddler
Hello, I had a question about cleaning and Maintaining Microfiber towels (and pads too!!) What should I use to clean them? (Detergent? Nothing/water only?) Should they be machine washed? Machine dried? Air dried? Cold water? Hot Water?
Please enlighten me as I would love to clean my MF towels without degrading its ability to leave a streak free shine! (I heard in the past that chemicals, such as detergent, might keep my MF towel from leaving a streak-free shine after use).
Thank you!!!
Use a dedicated microfiber detergent, dry low to medium heat. You'll be fine. I always suggest Blackfire microfiber cleaner.
So it is okay to machine wash? I usually hand washed them because of the added expense of running the machines for such a small load. (Five to six MF's). Can I use the same process for the pads too?
I explain my entire process and my results here:
[ame=http://www.youtube.com/watch?v=k61suqb2SJI]How To Clean Microfiber Towels The Easy Way!!! - YouTube[/video]
I use a detergent, but not a lot of it. Warm water on the delicate cycle and dry on low heat with no drier seats.
I hand wash my pads, but then again, I don't do anywhere near the business that some of you do. I have time in between jobs, so it's no big deal to hand wash most of my stuff.
No disrespect to Roshan intended but I do take issue with a couple of the statements in his video. IME new towels, especially dark colored ones, can bleed and transfer dyes. It usually stops after the first few washes but be aware that this is a possibility. Also, the reason for not using fabric softeners with microfiber towels and mitts is not related to static. If anything fabric softeners actually will reduce static but fabric softeners work by leaving a coating behind on the fibers which adversely affects absorbancy - not what you want on your microfibers.
You can use fairly hot water, at least up to 158F/70C, without damaging the fabric and higher temps in the wash cycle may improve cleaning. Too much heat in the drying process, however, is not a good thing. I usually dry my towels on low heat until they are about 80% dry and then let them dry the rest of the way on an air only (no heat) cycle. I don't like hanging them outdoors because they can pick up airborne dust and pollen. Per Roshan the Blackfire Microfiber Cleaner & Restorer works great (thanks, Al!).
MF towels-
I wash MF towels in CG MF wash. I would stay away from powdered detergents. During a detail I have Purple Power and water in a 5 gallon buckets 10:1. Just 2 or 3 gallons. When towel is done in the bucket it goes. Just to keep products and stains drying and setting in the towels. When it is time to wash. I wring them out in the washer they go with liquid MF detergent. I use hot water with cold rinse cycle. Then run them one more time through a light cycle with water only. Then in the dryer they go. If you are not using a dedicated washer an dryer run the dryer for 5 minutes then clean the lint catch. Then put your MF in on low to med heat.
Most important- Never wash or dry MF with cotton or anything else. Separate loads between really filthy and just dirty. I sort and wash. I always wash my wax and sealant towels by themselves. When you first get new towels wash them before first use.
Pads
I only use foam and MF pads. MF pads get CG MF wash. Foam gets cleaned with CG pad cleaner(very economical 16:1 dilution ratio.) I use the same set up. 5 gallon bucket with about a gallon of Purple Power 10:1. When a pad is done in the bucket the face of pad down. When I'm done detailing I rinse well under cool water wring excess water out. With Pads I saturate with pad cleaner. Agitate by hand to get it to foam up.I leave to dwell face of pad down. I just use a dish drying rack. Then I rinse well with tap water until all product residue is gone. Wring out then back to the drying rack to air dry facedown. Once they are dry. I hit them with some compressed air before they get packed up.
Most important- Make sure they a dry before you put them away. If they are not dry they will end up developing mold inside a sealed bag.
I always dwell and dry face of pad down. Let gravity do it's job and pull the water and any possible residue down through the face of the pad. Clean from the inside out so to speak.
I have used Sonus De Wunder Wash and Chemcal Guys MF wash. I like both the CG is cheaper but they both do excellent jobs.
I love the CG pad cleaner cuts 16:1 and it cleans pads like crazy. It took me a while but I realized process was more important then product. Hence this long post and my OCD cleaning process.
does anyone use any sort of brush on the microfibers to get some of the matted fibers fluffy again? or is the microfiber done when it stops feeling as fluffy as it used to?
What water temperature did you use, and would you be more concerned about dye transfer if the colored towels were new and had only been washed once or twice?
Thanks.
To be honest I'm not 100% sure of the water temp. I just put it on a hot/warm cycle.
I've never had dye transfer ever yet.
This is what I do.
3 5 gallon buckets full of hot water and 2 oz's of APC+ for 30 minutes in very hot water.
Why 3 buckets? 1 exterior,1 interior,1 for everything else towel wise.
I let them soak anywhere from 20-30 minutes but turning them every 10 minutes and getting as much out by hand as possible.
I then throw them all in the wash on large load hot/cold with micro restore MF detergent and 3 oz's of APC+.
Before the spin cycle I turn the washer off and allow them to "Soak" for about 15-20 minutes then proceed to let it go through the normal wash cycle.
For drying I use low heat timed at 30 minutes then no heat fluff dry the rest. Fold and put in bins :)
This is what I do.
Exackly this procudure except the machine washer .. i do it all by hand .. 3 buckets ,one for pads,one for polishing buffing mf ,and one for all porpuse mf ..
and once in a while some white vinegar in the mf
Just tried this method last night on my drying MF's that contain Cobra guzzlers and 2 600 gram towels:
1. First load on hot water with 1 cup vinegar (no rinse cycle). This will remove any contamination or soap residue (vinegar is acetic acid).
2. Second load on hot water with 1/2 cup of baking soda with a regular rinse cycle. The baking soda (sodium bicarbonate) will do the actual cleaning.
3. Dry towels on low heat (prevents edge curling and fiber damage).
I was happy that finally ALL soap residue had disappeared from my towels, as I had been having a problem with soap being left behind after the initial wash of MF Restorer detergent or Tide HE. Got tired of running 2 and 3 rinse cycles and this method above seems to have eliminated the problem. Towels came out clean and soft. I think I will be using this method for my drying and glass towels (non heavy duty use). For the towels that see polish/wax and for general cleaning I will continue to use regular detergent and APC. -Ed
