PERFECTIONPLUS
- Apr 12, 2012
- 156
What do you prefer and why? Ready ... set ... GO!!!
I use both on pretty much every car. MF for cutting and foam for finishing. The MF offers more cut while still finishing very well and foam just finishes better IME.
I will say that if I could get MF to finish as well or better than foam I would use them for everything. There is something about them that makes me like using them more than foam... maybe its partially because I feel they can get in closer to trim and emblems safely and they do a better job at cleaning out those areas too.
Chad you just might be 100% MF after Sept 22nd!!
So, is there any advantage to using MF pads rather than foam in this situation??
I'd never touch a foam pad again if I could get MF to finish down as well as foam. Sept 22..?..can't wait to see what that is all about.
