Hello Mike,
Thank you for taking the time to answer my email regarding my polishing tool dilemma questions today! I have a few follow up questions before I start my purchases, so I’ll be sure to post in the forums from here on out.
First, I’m going to order the FLEX Supa BEAST per your recommendation, but should I return my Milwaukee rotary? (I still have time to get my money back from where I purchased it.) Not sure if a rotary is necessary since I will only be polishing family/friends vehicles. There may be times to wet sand, but I highly doubt it would be an entire vehicle, so I’m thinking the Supa Beast will have me covered. Please correct me if I’m wrong.
Second, you mentioned to follow up with a Porter Cable instead of the Supa Beast to remove rotary holograms on softer paints, but would that still be necessary if I were using the Supa Beast from the start and not a rotary? (I also plan to use the Supa Beast for 1 step corrections.) If yes, would the Griots G9 do the trick too instead of the Porter Cable, or is that too powerful?
Lastly, with the Supa Beast in hand, should I also get a mini polisher like the Griots G8? Looking to cover all my basis.
Thanks again Mike!
Thanks again Mike!
