Mirka Abralon or Meguires Unigrit
Whitewater25
Member
These 2 products look similar. Wondering if they are. I see the Mirka has 4000 grit available where the finest Meguires has is 3000. Are there any other differences I'm missing & is one supposed to be better than the other?
I was thinking of trying it wet on some stage 3-4 gel coat. It's mine so I don't mind it being the Guinea pig. Might try it on headlights as well. Not sure in my abilities to try it on paint just yet. I would like to get a little shine back to the gel coat if possible. The boat is 25 years old, hull is in decent shape but inside has seen its share of sun & could use some help. Not sure painting it isn't the best option but time & funds won't allow that anytime soon.
huh, I thought Mirka made MEGUIAR'S I woulda figured they were the same. I too am interested in the differences.
I wanted to try the Unigrit Discs, but they seem to be discontinued(?)
So then I considered 3M's Trizact, but the cost told me no.
I ended up getting sanding/finishing discs from the Mirka Abralon line.
I wanted to do some damp sanding on car paint with these. Used on a PC.
Mike Phillips, did I screw up by getting this? :doh:
On my test panel, I used the 1k, and followed up with 2k. Then compounded. Everything appears fine, so far.
