Mixing #205 and Ultimate polish
imranhakro
Hello,
Can i mix #205 and Ultimate polish for better results?
Reason why i think so:
  • #205 is great finishing polish but more cutting than UP
  • UP is also great finishing polish (consumer line) but bit more oils than #205
Thus mixing both may give the flawless results, because combo of both may create a synergy. Any comments?
Regards,
Imran
Many here do some experimenting on their own and while it's not recommended by the manufacturer but where these products are so close and by the same company I suspect in this case you'll be fine.
How will you control the formulation?
1:1
1.5:1
2:1
You should do a test and post the results.
It was just a random thought...
for formulation i dont have any specific ratio in mind. few pea size dropes of each product on pad, and work my way..
You certainly can use that approach but what if you stumble on a combination that works, how would you duplicate it?...
The way i did it initially... :laughing:
i mean i will do trial and error to see what ratio works out
I'm not sure I understand the logic behind mixing the two. Mixing 105/205 I understand, but why two products that are so close to each other in purpose/cut/makeup?
